2009-01-13 04:21 PM - last edited on 2023-05-26 02:42 PM by Rubia Torres
2009-01-13 09:51 PM
2009-01-14 02:01 AM
Derek wrote:I have only had the occational "crash" where the bug reporter comes up.
update:
i thought it was linked to the Ctrl key but but unfortunately it's a lot more random now...
most crashes occur in the 3d window. any kind of editing in the 3d window and i'm worried that AC will crash.
on the advice offered in other posts i have tried the internal 3d engine but no improvement.
the 'as in photo rendering' in the 3d window prefs is off and the 'single color' is on.
have also tried removing all preference settings as suggested in the Archicad Wiki.
still crashes...
2009-01-14 03:14 AM
2009-01-14 06:31 AM
2009-01-14 06:57 AM
Erika wrote:Quite possibly, but I do try to turn it off when not needed as I know it can (or did in version 11) stop the Info box from showing the correct infomation.
do any of you have the trace reference active when this is happening?
2009-01-14 07:06 AM
2009-01-14 01:37 PM
Erika wrote:my trace is off. however, i've noticed something strange (probably just a coincidence).
2009-01-14 02:15 PM
2009-01-15 01:38 AM
Derek wrote:I can't confirm this no matter how close I zoom.
ok, i can confirm what i said above:
start a clean project using default template and workspace.
create a rectangular set of walls (in my case 5m x 5m x 2.5m high x 300mm thick)
insert a window (any window)
now edit the window. it doesn't matter if i edit in the 2d window or the 3d window. if i'm zoomed in pretty close then as soon as the project rebuilds, AC crashes. if i'm zoomed out enough (haven't found the point of no return but usually 'zoom extents' is fine) then all is ok.
