random dimensions attached to window markers
a lot of the time when move my window markers (for example, from the center of the window in the plan to the edge as to allow for an easier dimension reading), these random dimensions just appear and attach themselves to the marker with the other end of the dimension attaching itself to a random point in another plan, usually spanning hundreds of feet.
another thing i've noticed is that whenever i change anything marker-related in the window and door schedule (through the open source view window), a lot of the times dimensions will change or disappear completely.
any ideas as to why this is happening? is there some property that window and door markers have that i'm not aware of?
1 REPLY 1
Djordje
Screen shot?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
