Tom Krowka
reference level and level dimension
Any way to set a dimension level to read to one of the reference levels rather than project zero? I have slabs and mesh which I need to set a level dim to sea level, which obviously is different than project zero. Seems obvious, but I can't figure it out.
Would appreciate any help.....it's Friday pm and I think I might ask Mr. Walker......Johnny Walker that is.
Thanks.
Tom
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
6 Replies 6
Stress Co_
Set the Sea Level elevation in "Project Preferences" .
Marc Corney, Architect
Red Canoe Architecture, P. A.
Stress Co_
Then change the existng dim. by selecting the text and use the pull-down menu in the "infobox"
Tom Krowka
Ah....did not look there. Thanks. Will check it out.
Tom
[email protected]
www.walshkrowka.com
Can anyone explain this?
I can explain my last post. I used the standard dimension tool, when I needed to use the level dimension tool, with gravity set to mesh. Hope this helps someone!
My first guess would be that your elevation marker is not at the same height as the mesh node.
