roof section problem
i have a section cut through a rooflight, and archicad is making the background of the hole in the roof dark grey
there doesnt seem to be any settings in the properties to change this background colour
i have done it before in archicad and this didnt happen
5 REPLIES 5
heres a screendump showing the prob
Percy,
Not sure if this is what you're after but you could try Section Selection Settings - Model Display - try changing the 'Fill uncut surfaces with' to 'own material colours - non shaded'.
Screeshot attached.
HTH
i already had it set to "nothing" because the colour of the material of the edge of this roof is dark grey
i dont want it to show as a colour on the sections. this seems to be a bug in archicad?
Erika Epstein
The hole that the skylight is cutting in the roof shows not perpendicular to the roof edges contrary to the rest of you drawing. This is a common problem with lower slope roofs.
Select the roof and with your mercedes cursor on an edge of the skylight hole.
Click and select the top right button of the pet pallet "set roof edge angle" and change it to the angle you want. Use the 'apply on all edges' if appropriate.
This may or may not solve your gray blob setting.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks, i wondered how to clear up the funny angles thing!
