roof
hi
i've got question. how i can create roof above ramp. this ramp is used by cars. shape of roof should be arched. how do it in archicad 10
2 Replies 2
Select a beam, and give it an angle (same angle as your ramp)
Place it along your your ramp, on your plan.
Then chose the profile manager and draw the section of your arched roof.
Then with your profile manager open, go back to your plan, select the beam and from the profile manager click on the "apply to selection" button...
that's it
LukasB's idea is nice.
There is another solution if the cross section shape of the roof is a regular semi circle. Use the object "tube" of the Geometrical primitives folder, it can be inclined by any angle. Cut the lower half with a roof or using solid element operations.
