‎2004-11-20
08:59 PM
‎2023-05-23
03:39 PM
Rubia Torres
‎2005-11-04 09:38 AM
‎2005-11-10 05:20 PM
Link wrote:Good tips get better by time! This one tasted just like a good old wine today when I helped out a client!So, here's the "special solution" (workaround):I "believe" you can simply place the skylight without changing the pitch, and make perpendicular just the angle on the upper side of the roof hole.
Change the pitch of your roof to be steeper than you intend so that you can insert the skylights without the error.
Now, select the roof (only). If you are 9.0, it does not matter what tool is selected. In earlier versions, select the roof tool. With the mercedes cursor on any skylight hole edge (if you are changing all), or on the top or bottom edge (if you are only changing those two), select the edge angle button in the pet palette as shown in the attached screenshot. Make the edge (or all edges) perpendicular.
Finally, change the pitch of the roof to the pitch that you originally wanted.![]()
Link.
