roofs and walls below
hi!
i'm drawing a loft but getting the walls below the roof height as solid lines with the cut line at 1200mm above the floor level. i need these wall contours to either be dotted or not to be seen at all on the plan. the wall contours above the cut line need to be seen as solid lines of course. how do i set this up? the roof shows as dashed above the cut line and solid below which is correct.
urgent as usual...
thanks
jonathan
v10
3 Replies 3
Djordje
Change the cut lines to dashed and the overhead lines to solid.
But ... I don't see how this can be correct presentation ... maybe if you posted a screen shot?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
hope the pdf is ok, i don't know how to save a screen shot...
yours
jonathan
yours
jonathan
There are screen shot programs that can grab a window on the screen or (for PCs) you can also use the 'print screen' button on the keyboard to copy the screen to the clipboard, then paste it into an image program to crop, save, mark-up, etc.
