rotate in vertical
I have problem with my model. I try to make gong to hang on the wall. I use floor tool to make a circle, but I don't know how to retate it to vertical. Please help me out, I need to turn in this On Tuesday. Thank you!
14 Replies 14
Djordje
ashley wrote:
3D studio max can render ArchiCAD's model? I also know 3D studio MAX. Can you teach me how to transfer the model to 3D studio max? Thank you!
Save as 3DS ...
Got to Tips&Tricks; there are a couple of tutorials by Stefan.
Browsiung the Presentation forum should also help!
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
thank you :lol:
Ede:
sorry to bother you! It works perfect, but the problem is I don't know how to use the GDL object that I just create. I can open the GDL from the project that I am working on, but I have problem to use it as library part. Could you show me again how to use it? Thank you
If you saved it in a folder which is added in the library manager to your library folders you have to be able to use it as a library part.
You do not have to open it until you don't want to change the GDL script
Regards,
Ede
thank you! It finally work.
