rotate on y axis
I'm new to ArchiCAD. I am trying to make a corbel column cap. I drew it in plan with the mesh tool and extruded it up. Now I need to rotate it on the y axis and it seems to only rotate on the z axis.
How can I fix this? Is there a better way to create the object?
1 REPLY 1
Assuming you're using AC16 or later, select the mesh, right click and "Convert selection to Morph". You can now rotate in any direction you wish in 3D window.
