frankgallagher
How to make an ellipsoid in Archicad
I've tried using the Revolved Geometry method but the problem with the ellipsoid is that I need all of its dimensions (width, length, height) to be different. Once I revolve the geometry, it means the width and height are the same, since it's rotated around an axis. Is it possible to modify this?
1 Solution
CosminF
There is an ellipsoid object in the standard library. Doesn't that help you?
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
CosminF
