3 weeks ago
- last edited
8 hours ago
Gordana Radonic
I've tried using the Revolved Geometry method but the problem with the ellipsoid is that I need all of its dimensions (width, length, height) to be different. Once I revolve the geometry, it means the width and height are the same, since it's rotated around an axis. Is it possible to modify this?
Solved! Go to Solution.
3 weeks ago
- last edited
3 weeks ago
There is an ellipsoid object in the standard library. Doesn't that help you?
3 weeks ago
- last edited
3 weeks ago
