rotate the detail marker
i am using the built in detail marker in archicad 11.... i have details that are rotated in plan and would like the marker to be rotated with the same angle.... i can do this in the settings just fine... but when i attempt to resize the marker line... it will not let me...
how can i rotate the marker AND resize it
1 Reply 1
Right now, you can't. (This should be a high priority item for GS). About the best you can do is using a linked section marker at the moment. (Built-in section marker seems to do the best for me.)
Richard
AC26 (since AC6.0), Win10
