round/soft corners.
I'm making a 60's table and need to make it feel softer. Is there any way to make round/soft corners?
TomWaltz
How are you building it now? Do you have a photo of what you want? I'm not sure I can picture what you are trying to do.
Tom Waltz
Just making it out of my mind
maybe this would help a bit.
i used the Profile mannager to create a profile with round edges and used it with the wall tool.
then i basically modelled the edge of the table with the profile i made and then just filled in the middle part with a slab. if you render it you would not notice its made out of two componets.
Hope this helps....
