I have a problem replicating a scaled fill from one part of a drawing on to another.
If I use the dropper, to pick up the attributes, then use the magic wand to fill the boundary, my new fill knows that it's a scaled fill, but it doesn't know what scale. Problem is: neither do I, so I don't know how far to drag out the scaling handle.
As a work-around, I copy a block of fill and then edit it to fit the new space, but this is much more time consuming than using the magic wand.
Is there a simple solution to this?
