‎2006-04-13 10:44 PM
‎2006-04-14 12:31 AM
‎2006-04-14 02:45 AM
‎2006-04-14 09:18 AM
‎2006-04-19 06:34 PM
Scott wrote:do u have to unlink the sections/elevations to proceed to the final working drawing set?
If I understand you correctly;
1 Unlink desired sect/elev,
2 Select all & drag a copy to the side,
3 Select lines and arcs only of copied elements,
4 Use hammer tool to modify linetype to sketch line.
5 Modify scale to alter appearance of sketchy-ness.
Hope that's what you're looking for.
S
‎2006-04-19 10:04 PM
im afraid when there are changes made to the model i will have to do the section over, what do i do?That's exactly why it's better to use the Sketch Rendering Engine. Unless you need a vector based sketch drawing for some reason (can't really think of one) I can't see any advantage to using the modifying lines method. (the sketch render runs surprisingly fast by the way especially if you don't have vectorial sun shadows and vectorial hatching)
‎2006-04-20 11:25 PM
