selection amongst beams at same location but various levels
There are two beam at same location on plan but a different levels, how can I choose on plan from them? (in Revit press ALT may select one or other)
Thanks
In Archicad it is TAB.
Hover over the beams and the pop-up info box will say "Multiple Elements (TAB)".
Please don't take offence (and keep asking questions), but by all of the basic questions you are asking, I think you should at least go trough the training guides for Archicad.
https://www.youtube.com/user/Archicad/playlists?view=50&sort=dd&shelf_id=17
I took Lynda.com but maybe need more training course
OK Thanks Barry
