‎2013-08-20
09:09 PM
‎2023-05-23
02:34 PM
Rubia Torres
‎2013-08-20 09:27 PM
‎2013-08-21 01:55 PM
Jonathan wrote:You can save the Morph as an Object, which will burn in the SEO modifications, then place this Object and convert it to Morph to continue editing. Repeat as needed.
I usually hide the operators on a hidden layer, but am wondering if there isn't a better way to do this. Or, maybe there is a way to lock the changes into the morph so that it doesn't require the operators any more?
‎2013-08-21 02:15 PM
‎2013-08-21 07:09 PM
David wrote:Jonathan wrote:You can save the Morph as an Object, which will burn in the SEO modifications, then place this Object and convert it to Morph to continue editing. Repeat as needed.
David
‎2013-08-21 07:13 PM
Erwin wrote:
You can make SEO permanent on a morph in de SEO pallette/dialog thingy.
http://helpcenter.graphisoft.com/videos/archicad/3d-modeling/morph/advanced-morph-modeling-technique...
