shell tool
hi all
in ac 15
can I make a beam on the shell _ like red line on the attachment?
can I make irregular sky light with command like -wallhole- in gdl
thank
or like that
nourqueen85 wrote:
hi all
in ac 15
thank
If I understand you Beam question correctly, you want to create a Beam that is a sloped Beam and it aligns with the surface of that Shell.
You can use Gravity to gravitate the Beam to the Shell surface. Then maybe you could adjust the inclination of the Beam in 3D.
The answer to the Skylight question is no, I'm afraid.
nourqueen85 wrote:
or like that
About this curvy surface: I think it would be possible to do this with the Shell Tool.
