Learn more
show in 2d
how can show selected of 3d display in 2d display?
thank for your helping
12 Replies 12
Steve Jepson
Barry wrote:
...As far as I know this is not possible.
If you want to see only the
individual elements selected in the 3D window. put the selected elements on a Renovation Filter. Then in the Floor Plan switch to that Renovation status which has noting else in it.
I guess that would work if you are not using the reno filters for renovation purposes.
Steve Jepson
I have never had any reason to use Renovation Filters even for Renovation Projects. It is just a matter of using a Favorite wall type, layers, layer combos. Considering all the times Renovation Filters have caused me trouble, it would not break my heart if there were no Renovation Filters.
The reason to view individual elements in a Floor Plan which you have selected in 3D is probably for a temporary situation anyway. Otherwise, the things you want to show on a Floor Plan/View map would be selected differently.
