site models
What is the best way to create an accurate topography in ac10? I currently have the site modeled in sketchup, but dont have a dwg of the terrain, though im sure i can make one from the sketchup model
Use the mesh tool. If you have a clean DWG then you can use the magic wand to create the mesh from the boundary and then apply the contours. The top of the mesh will still be flat so the contours must then be raised to their correct elevations. This is best done in plan (the leftmost item on the pet palette) since there is an "apply to all" function that lets you raise each contour in it's entirety (you can only adjust individual nodes in 3D ).
If the DWG isn't clean it may be easier to enter the metes and bounds for accurate property lines and trace the contours with the spline tool.
There are some subtleties to this, but it is easy enough that you should give it a try and then post any further questions.
Ok, that brings me to my next question...since I belive I can export a decent dwg from my sketchup model, how do I import this accurately into archicad? I have tried this on other assignments and it has been less than successful
