skylight solutions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-05-20
05:54 PM
2023-05-23
03:42 PM
Rubia Torres
2004-05-20
05:54 PM
When inserting the skylight, the roof slab projects beyond one side of the skylight, out through the wall and beyond into space.
So:
I changed the roof pitch, inserted the skylight and changed the roof slope back. Although, I did not receive the error, I did receive the same result.
What is the fix?
Thanks,
Jason.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-05-21 02:39 AM
2004-05-21
02:39 AM
Jason,
I am not sure exactly what you are describing
but I suspect it might have something to do with the
default edge angles of the hole that the skylight tool cuts in the roof.
If so you need to select the roof, click on the roof tool,
select the upper and lower edges of the hole,
select the edge angle icon in the pet pallet and
correct the angle to "perpendicular".
Hope this helps,
Peter
Hope this helps,
Peter
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-05-21 04:31 PM
2004-05-21
04:31 PM
Included is a screen shot of my problem (roof slab projects beyond the wall). Can you elaborate on your directions a little- Which view should I be in, and how do I select the roof, and then the edges of the hole?
Having a slope of 0 degrees works fine, but 1 degree causes a problem.
Thanks,
Jason
Thanks,
Jason
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-05-21 05:00 PM
2004-05-21
05:00 PM
The problem you're experiencing is actually the roof edge angle given to the hole in the roof, by the skylight.
To fix it, click on the roof hole edge, while in the roof tool, and change the angle ofall the sides (of the hole) to perpendicular.
See the attachement.
Link.
Link.
