slab offset
I want to draw a slab 6mm offset from the exterior walls. This is to create a capillary break from the exterior cladding. How can I do this?
10 REPLIES 10
Select the slab you want to offset
Click on one of the nodes
A pet palette appears select the offset edges icon and offset
Add computer specs and AC version to your signature
David Maudlin
Graeme:
Use the Magic Wand with the slab tool selected on the exterior face of the walls to have ArchiCAD automatically create the slab, then follow Jae's instructions.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rocorona
*AND* don't forget that ArchiCAD has also the OFFSET command.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Thanks for your help. It worked perfectly.
Djordje
... that you can invoke BEFORE you start drawing or tracing the outline, and specify the offset when you finish it. For best results, activate Coordinate box and Control box and forget the Tricker.
Yeah, yeah, old fashioned, I know, I know ... I still want a manual car!!!!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
Djordje wrote:
...and forget the Tricker.
Boy Djordje, you really do hate that thing!
David
Djordje
David
Bad memories Now it mostly works, but still, the functionality of the Coordinate/Control box is poorly implemented in the Toolbars. No wonder people say you can't draft in ArchiCAD ...
Djordje
HP Omen
Aime
what is the tricker?
thanks
Have you seen the light?
AC 12, AC14, win 7, Hp pavillion dv6 2.4Ghz, 4gb Ram
Dwight
The tricker is the guy who sold you Archicad.
Dwight Atkinson
