slanted-straight intersection
hi.. ok i used to have this problem sometimes with linear-slanted walls... but now its always with curved slanted " or profiled" walls .
i don't know but this doesn't seem to be OK?
any ideas ? tips?
Trace the projections in 2D and then switch the walls to cut only.
I think your problem is identified in Archicadwiki here -
http://www.archicadwiki.com/TechNotes/Intersection_of_curved_slanted_and_complex_walls_in_2D?highlight=%28TechNotes/%29%7C%28%E2%80%A2+ArchiCAD+11%29
They suggest using the patch tool.
Sorry, it's not a lot of help to you but at least they have identified it's a problem!
hmmm...sad
we are getting more and more problems because 2D plans are not real projection!!
i know its a huge step to reprogram that... but now we are having real issues.. we are not talking about Stair hand rail... no talking about SEO .. now we are talking about WALLS!!
any way thanx for reply
