slanted wall healing with slab
Hello all,
Is there a way to have slanted walls heal with slabs like stright walls?
thanks
Habi
Use help lines....
Extend the slab so it intersects the wall and use SEOs (solid element operations) to clean them up. In this case adding them together or subtracting the wall from the slab would do the trick. For precise positioning you can drag the slab in the section view and then stretch it back to the other wall in plan.
