Llian
slider in the middle of frame
The slider panel is shown here as aligning to the frame. How do I get it into the centre of the frame?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Unless your object has a parameter that allows you to adjust the panel positions in the frame then you can't - if you want to keep it as an object.
I would doubt this parameter is there but if you tell us the name of object you are using then someone else that uses it may be able to tell you.
There are 2 other options.
Learn GDL or convert it to a morph and manipulate it (sometimes easier said than done).
