soft fills in archi 13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-01-02 06:34 PM
2010-01-02
06:34 PM
I want to start using the intelligent insulation in 13 except that I cant get started. I have 2 basic question if anyone can help.
1, I cant seem to find the symbolic fill for the soft insulation fill. Is it hiding somewhere, do I need to load it into the library?
2 How do I get the cut 3d image showing the composition of the walls?
I want to prepare a cut image of a buildings structure. When I try and do a cut with the cut tool in 3d settings , I dont get the internal componants.
What am I dong wrong??
merci
Lisa
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-04 12:24 AM
2010-01-04
12:24 AM
OK, ive managed to get the cut view using 3d document, thats ok
Still cant find the soft insulation fill though
Have I accidently written over it perhaps? is there a way to reset or reload default fills library??
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-04 01:30 AM
2010-01-04
01:30 AM
upintheclouds wrote:Lisa, check to see you have selected it in the Fill Types.
/...Still cant find the soft insulation fill though/....
And also be sure you set your composite correctly. HTH
Rod Jurich
AC4.55 - AC14 INT (4204) | | OBJECTiVE |
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-04 03:53 AM
2010-01-04
03:53 AM
Thank you Rod, I started up a new project using the default archi13 template and voila, I have a load of fills that are not present in the project template I created myself back in 12.
My bad, I forgot the rule about being careful in using project templates created in older versions opened in new versions of archicad,
I guess I need to recreate my project template, starting from the archicad 13 default setup to take advantage of the new content.
thank you for your input
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-01-04 01:48 PM
2010-01-04
01:48 PM
upintheclouds wrote:Lisa, no need to begin from scratch.
/.......I guess I need to recreate my project template,
Use the Attribute Manager to bring in the new fills to your working template.
This I do with each upgrade. Glad you got it sorted.
And you can do similar with your Work Environment to bring in new tools etc
that come with new upgrades.
Rod Jurich
