solids editing? subtraction
When I am using the subtraction in targets and operators, Which seems to be very straight forward and understandable, I get denied.
How does one subtract one solid from another, in my case roof from column.
10 Replies 10
TomWaltz
How are you being denied? Are you getting an error message?
Or does Archicad not do anything after you click "Execute"?
Tom Waltz
Archicad does nothing when i click execute
TomWaltz
It could be the angle. but it does not look like the chimney actually intersects the roof. Is that true?
Tom Waltz
Link
You'll probably also want to use one of the subtraction with extrusion methods.
Link.
If you have done a simple subtraction (as opposed to "subtraction with upwards/downwards extrusion") you will not see the effect if the roof is still visible. And the original extent of the object will be highlighted when selected, not just the bit that is left behind, I think (not proven).
tried it with upwards and downwards extrusion. It is still not working.[/img]
now something buggy is happening. I get error in picture below and when i click stop an error messege box pops up with all sorts of strange information.
ok i think i have almost got it. But I don't need the operator part which is the box elevated above the new hole in the roof. When I delete the box the hole fills back in with roof. How do I delete the box but keep the hole?
TomWaltz
You can't. The whole point of Solid Element Operations in Archicad is that they are interactive. As soon as you move the operator, the target updates to that change.
Most people keep an "Operators" layer (usually set to "wireframe") for keeping operators that you do not want to see.
Tom Waltz
