2006-01-21 06:04 AM - last edited on 2023-05-25 05:02 PM by Rubia Torres
2006-01-21 07:34 PM
2006-01-23 04:41 AM
2006-01-23 11:57 AM
2006-01-23 12:02 PM
2006-01-23 03:35 PM
2006-01-27 10:27 PM
Z.Bauer wrote:That's true, especially with some stairs (I forget if it's only with ArchiStair stairs or all of them). That's why the "roof" work-around. It may be a bit more of a headache in your example, but it's probably the only way. Unless you use ArchiStair, which has an option to show a wall under the stair (left, right, or both sides).
As Erika said sometimes some objects aren't possible to trim using SEO.
