split levels?
Here's my problem.
I have a large exhibition space 6 meters high. And I want to insert a new level at 3m over part of the exhibition space for offices etc. How do I go about getting to show the plan for the split level? I need to show the two separate plans, one at level 0 and one at level +3 but without creating two different stories. Or is that not possible?
Cheers.
6 Replies 6
Saved views with different cut planes may work.
Then you can put the two tightly next to each other on the same sheet
possibly?
lec1212
how exactly do you mean? I understand the idea of the different cut planes for a given plan but do you mean a different height cut plane for the plan or a cut plane in the 3d document? Could I have copies of the same floor?
You want to be working with saved Views -which become your drawings...
You can have as many Views of a single floor as you want, with each view having different saved settings. In this case, you want two saved views of the same floor - each view with a different Floor Plan Cut Plane. For example, the FPCP for the first level might be at 1 meter and the second might be at 4 m. (The structural plan for the higher level might have a cut plane at 2.8 m to cut through support beams.) Etc. Different values for above/below determine how much of the model is projected into the view.
A presentation view of the same plan might have solid wall shading and a layer combo that turns on colored fills/etc. Model View Options let you control many things here - different saved Model View combinations for different views. A key plan would be the same floor at one scale where detailed plans would be portions of the floor at a different scale. All just views of a single story / floor. 😉
@Karl,
that is exactly what I want, however I didnt find a Copy option for the individual fllor plans. How do I do that?
There is no 'copy'. You set up all of the settings to see things as you want - with properly named layer combo, model view options, etc - and then create/save a new view. Look at the documentation for how to create a View.
zoltar wrote:
Here's my problem.
Cheers.
Hi zoltar,
This thread (about "Split Level" also) might give you more help:
archicad-talk.graphisoft.com/viewtopic.php?t=31727&postdays=0&postorder=asc&&start=0
