stair problem
hello there
i have a problem with all my stairs. i want the stair to have the lines of the story sensitivity a little bit higher. they are on the 5th tread and i want them on the 8th. do you know how can i change the height of the story cut?
2 Replies 2
fuzzytnth3
Open the settings for the Stair and select "Edit this Stair" from the tiny little pop up menu, in the 2d plan view Stairmaker shows of the stair there are break lines shown, if you float your mouse over the ends of the breaklines the mouse will turn into a crosshair and you can then drag the break lines to the tread you want.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
thank you very much
