Patrick_lgs
stairs problem - how to solve it?
Is there a way to solve the situation o the image?
1 Solution
The only real solution I have found is to model the flights and winders separately.
If all one stair, the underside will become curved.
If modelled as separate stairs, the flights will have a flat base and you can edit the winders to have a flat base as well if you want.
See this post ...
https://community.graphisoft.com/t5/Modeling/Curved-Stair-issue-with-construction/m-p/283945
Go to post
4 Replies 4
Patrick_lgs
See this post ...
Patrick_lgs
Thank you Barry
If you use Barry's method, some landings may become very thick. In that case, you can even model the desired bottom surface with a Morph and subtract it from the Landing to achieve the exact desired bottom surface in all landings instead of the automatically generated bottom surface.
