strange cuts going through wall ?
i have an internal wall inside my house.
about 3 meters a´way there is a complex profile beam (gutter)
the gutter does not go any where near this internal wall.
But what ever i do, there is the profile cut of my gutter cutting straight through the wall ?
any ideas how to remove this little problem.
thanks.
Ian
5 Replies 5
thanks.
Ian
If the wall and the gutter aren't touching then they shouldn't interact with each other.
Turn all your layers on and see if there is another gutter lurking about.
Hi Barry.
your right, i turned on all the layers and then found 2 pieces of gutter walking through my walls.
funny enough in 3d, it never showed the gutters going near the walls but on plan, the end point of the gutter was to long and strectjing through the wall.
thanks barry for the help.
Ian
weird, i have just spotted that a few new posts on the forum have been double posted. multiplied ??
just seems to have been a kickup with the server maybe ?
Ian
vfrontiers
It must be your profile... Is it drawn as a BEAM... beam to wall cuts are brutal... Make sure gutter is on separate layer with different PRIORITY number....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
