strange roof - construction problem
can anyone tell me if its possible to build this roof? and how ? 🙂
and that little thing over the entrance? its built in autocad but i want it in archicad
17 Replies 17
TomWaltz wrote:
Did I mention I'm a big profiled wall nut?
You don't need to!
TomWaltz wrote:
You could do the one over the stairs as a Profiled wall too, just as two different ones, one for the "solid" frame and one for the wood joists. It would be a small maybe 1') length, then the joists, then another 1' length going side-to-side across the stairs. No objects needed and highly editable.
Me too. And now they can curve!
guys all this is great but i couldnt do it with the profile thing. too difficult and i think i m missing sth here. anyway. ill keep trying.
thanks 🙂
thanks 🙂
Perhaps this will help...
...and this...
(The red lines and arcs are just guides and have no effect on the finished profile)
Nice screenshots/examples of use of profiles, Matthew ... perhaps you would make this a Wiki article? 😉
A downside of using a roof (or beam) as Matthew has done is if you want to create a single schedule of your roof surface area (e.g.) - since these 'roofs' are not created with the Roof Tool. Tricks have to be brought into play to get proper schedules.
Matthew wrote:
...and this...
THATS PERFECT AND REALLY HELPFULL!!!!!!! THANKS A LOT 🙂
thanks 🙂
Great..
but actually i've faced some troubles.. regarding documentation... " the right appearance in floor plans"
and sometimes trimming other waals to that.. because of auto-trimming of walls.. i had to change priority to make SEO works
