structure display
Hi, could anyone please help me to connect the core wall in 'core only' structure display.
Thanks a lot.
( I dont want to display the finish skin, but the core not connect properly)
Is this a Floor Plan or a Section?
Which version of AC? Show the view with all skins visible for us. It seems that you have the skin priority for the core set to be not strong enough to connect the core skins together - the cores are not pentrating the (invisible) finish skins.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
