2009-05-04 11:41 PM - last edited on 2023-05-23 04:55 PM by Rubia Torres
2009-05-05 12:53 AM
2009-05-05 01:18 AM
2009-05-05 02:16 AM
Charlie wrote:Charlie, always model. 2D is last resort.
/....... Any suggestions on best approaches to modeling a precast concrete panel industrial building./.....[/img]
2009-05-05 02:18 AM
2009-05-05 02:24 AM
2009-05-05 08:05 AM
s2art wrote:this is how i do mine.. pretty simple.. and u can move them when ever you want..
If you place columns where the vertical joints will be on a layer that is normally turned off they will subtract from the wall without having to use SEO. It's then easy to adjust them if required.
2009-05-05 04:27 PM
2011-03-18 03:55 PM
2011-03-19 05:40 PM
Mats_Knutsson wrote:I'm not sure I understand exactly what you mean, but to get a hairline in a profile you can add a node and set the materials differently to each side of the node. These materials can be copies of the same one so the appearance is the same (just the names are different).
I want to bump this one.
The column method is simple but what if I want the vertical line to be really thin, like hairline, and go thin like that to dwg. HowdoIdo?
/Mats
