2009-05-04
11:41 PM
2023-05-23
04:55 PM
Rubia Torres
2011-03-21 08:20 AM
Matthew wrote:For a facade I want hair lines in dwg.Mats_Knutsson wrote:I'm not sure I understand exactly what you mean, but to get a hairline in a profile you can add a node and set the materials differently to each side of the node. These materials can be copies of the same one so the appearance is the same (just the names are different).
I want to bump this one.
The column method is simple but what if I want the vertical line to be really thin, like hairline, and go thin like that to dwg. HowdoIdo?
/Mats
2011-03-21 08:54 AM
Mats_Knutsson wrote:See attached Mats, not sure of the final result you want.
/....... what if I want the vertical line to be really thin,
.....................like hairline, and go thin like that to dwg. HowdoIdo?
2015-05-03 04:46 AM
Rod wrote:This was really good, but I cant seem to get the joints to show in floor plan.Charlie wrote:Not any more Charlie, part attached.
/..So the vertical joints are hard to control./.....[/img]
2016-02-12 05:10 AM
Rod wrote:HI,Mats_Knutsson wrote:See attached Mats, not sure of the final result you want.
2016-02-12 05:20 AM
tranthainguyen wrote:That is because this is a window object and not a standard object.
I imported into library, then open object tool but it is not there.
2016-02-12 06:59 AM
Barry wrote:Oh ok. Thanks for the tiptranthainguyen wrote:That is because this is a window object and not a standard object.
You need to use it with the window tool.
