RandyC
survey point - new command in Archicad 25
I have read about the new command "Survey Point" - but cannot find it anywhere to add and explore - Does not show under new commands in work environment -
is this something that is coming out in a future release ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
14 Replies 14
Minh Nguyen
Dear All,
Thank you once again for the reports!
So far, we have identified the issue and recorded it as defect DEF-5914. The only workaround at the moment is to sort the commands by theme, then you will find the new commands for Survey Point.
Please let me know if you have any further questions. Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
LeeJaeYoung
I can't open it because I don't know the gdl name of the survey point.
If you know a name that can be opened, can you please let me know?
AC27 on window 11
@LeeJaeYoung ,
I am not sure what you are trying to open.
This post is about the survey point commands not showing in the menus and being hard to find in the Work Environment to add them to the menus.
The survey point itself is not a GDL object and can not be opened to edit.
Might be best to start a new topic if you have further questions about it, so it doesn't get lost in this post.
LeeJaeYoung
AC27 on window 11
@LeeJaeYoung ,
Please do not ask here for answers to other posts.
If someone wants to respond to those posts they will.
If you are not getting answers to those post, then please reply in those post asking for further help.
