suspended ceiling modeling and documentation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2018-05-04
05:23 PM
ā2023-05-25
05:36 PM
Rubia Torres
Archicad 28
Mac OS '15 Sequoia
Hardware: M4 Max with 16-core CPU, 32-core GPU, 40 core GPU, 16-core Neural Engine, 64GB unified memory
1TB SSD storage
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-05-05 12:56 AM
If I need to schedule how many of each size tile there is I can exploded the slab/tiles into morphs.
The way to generate the Reflected Ceiling Plan then is with the Floor Plan Cut Plane Settings of the RCP View.
This will depend on how you have your Stories set up and what Story you have the beams and slab displayed on. Personally, when I need to make a RCP for a suspended ceiling I add a Story to the model just that.
I model the fire sprinkler escutcheons, lights, smoke detectors, grills, vents... on that Story as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-05-06 08:33 PM
RWARCHPC wrote:Out of curiosity, I downloaded and tried out the USA ceiling accessory provided as part of ArchiPlus. (You also need the standard Accessories Goodies, as it's a slab accessory.) It works just fine in v21, and is very simple. It's not a true 3D solution, but gives you adjustable grid lines on the bottom of a slab (and plan), where all of the intersections are snappable. Throw some of the GS standard 3D troffers in there and I'd say it looks pretty darn good and is not likely to cause file bloat. I'm not sure why people are saying it's not supported in v21.
Can anyone make a suggestion for modeling and documenting a commercial suspended ceiling system in ArchICAD 21? I have read other posts here that seem to indicate that the ceiling editor / v21 is no longer supported .
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-05-07 09:26 PM
I will look again. When I tried this out initially, I found that laying out the basic grid was not a problem with the ceiling editor or any of the ceiling objects I tried from Armstrong or Certainteed found on bimobject.com (they are essentially the same object with different mfr names and available only for non-US versons). What I found in all cases was that none of the tools were able to host anything like light fixtures, diffusers, etc. The ceiling editor appeared to have some kind pet palette one could activate for fixtures but mysteriously disappeared when selected. I found nothing in the bimobject tools that allowed me to host anything. I'll go back to the Archiplus page and see what's there - maybe my version was out of date.
Archicad 28
Mac OS '15 Sequoia
1TB SSD storage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-05-28 05:53 PM
Thanks Richard and Steve for responding....
Archicad 28
Mac OS '15 Sequoia
1TB SSD storage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-05-28 06:55 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-05-31 01:57 AM
Thank you. That's exactly what I wound up doing.
Archicad 28
Mac OS '15 Sequoia
1TB SSD storage
