2004-11-1505:06 PM - last edited on 2023-05-2303:39 PM by Rubia Torres
2004-11-1505:06 PM
Hi guys!
I already searched for the answer in the topics you already inserted in the forum but I just found some solutions for archicad 7 or higher. I work with ArchiCAD 6.5 EDU. I'm afraid there is no solution for this one:
I'm working on a project with many different textures (most of them are signs - created in Photoshop). As I recreate the needed form for those signs with different tools I need to use them on almost all of them (specially, slab, roof)
The textures seem to start at any random point and I can only center the texture moving the elements but once saved as bibliothec-objects the textures don't keep in place!
I already tried many things but I still can't find the solution.
In this case I can't use the picture-with-frame-object as the forms are very irregular or round in most cases!
This texture setting option in 3D was not available in AC 6.5. It was part of the Special menu though. So you can press CTRL-ALT while starting ArchiCAD for the Special menu to appear and then you can use the command in 3D.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
Hi laszlo!!
Thank you a lot for your tip!!!!
It works!!!!! 😄
I was already desperate and almost gave up!! You surely know that feeling!!
thanks again!
bye
