‎2005-02-04 07:51 PM
‎2005-02-21 12:08 AM
Aussie wrote:sorry, I meant 30 mm glass panels !!! (not 3mm!) [mistake]
Charlotte. depending on the type and size of building , elements in it generally need to be resistant to fire. Steel inits raw state is poor and will collapse undr a fire load and as such needs to be encased or coated.
The glass idea could work acoustically it would be like having two windows but 3mm sounds a bit thin (physically and acoustically)
‎2005-02-21 12:15 AM
‎2005-02-21 12:20 AM
Aussie wrote:just to separate some rooms (imagine a building for students) with glass!
To be honset I am not sure what your concept is. What is trying to achieve?
‎2005-02-21 12:27 AM
‎2005-02-21 12:54 AM
‎2005-02-21 01:07 AM
charlotte wrote:Aussie wrote:just to separate some rooms (imagine a building for students) with glass!
and for all the height of the building then it will create like high empty glass passage...... what can i put inside this passage then???
thanks
‎2005-02-21 01:24 AM
