‎2004-02-27 01:31 PM
‎2004-02-27 05:14 PM
rgarand wrote:En general the shortcuts work better with the Caps Lock off ...
I was trying out a few of the new toolbar shortcuts and have found a little problem...or maybe this is how it is. I was trying to switch from arrow tool (1) to the text tool (E). If my cap lock is on the E shortcut does not work. If caps lock is off the E shortcut works.
Has anyone else run into this?
‎2004-02-27 06:51 PM
‎2004-02-28 06:04 PM
rgarand wrote:Not me. All caps text is unreadable, and I still lament the lack of the CapsLock function in selections ...
Maybe this would be a good thing to fix. I am going to go out on a limb here...but it would probably be a pretty good bet to say that most of us using ArchiCAD have our Caps Lock ON the majority of the time. Just a thought Graphisoft
‎2004-09-02 08:23 AM
rgarand wrote:Yes I use Caps Lock On mostly, and I just discovered this problem the same way, trying some of the shortcuts!
‎2004-09-02 03:07 PM
‎2004-09-02 09:14 PM
Jefferson wrote:All caps text is less readable than a normal one. Many researches showed that. Personally, I prefer legibility and information transfer (presuming there are some O;)) to looks
1st Djorde, what do you mean en general? And no caps/selection? My experience is caps on - no shortcuts. And with the caps on IthoughtI was toggling through the selections in an instance of overlapping elements. Am I not really?
‎2004-09-05 10:24 PM
rgarand wrote:It is fixed in 9.0
