trapezoid-base shaped vault
Hi everyone,
please forgive my english 'cause I'm Italian and i'm not familiar with this terms in english.
I just created a gothic cross vault (with sharp arches) by intersecting two straight vaults, so i got a square-base shaped vault.
Now i need this vault to have a trapezoid-base shape, and i can't figure out how to do it. I tried to convert the shells in morphs, but it's too messy to move all that nodes in position. Any suggestions?
7 REPLIES 7
Hmooslechner
To get a horizontal ridge of the roof, You can try first to construct it normally with raising ridge, then draw a new section through the ridge and rotate it back to horizontal.
Hmooslechner
here is another possible solution just in upload for about one hour:
https://www.youtube.com/watch?v=XA6YSEqPcGs
its open now.
A normal Gothic cross vault is relatively easy to accomplish. a trapezoid one is more difficult, but with the use of morph-Lines in 3D and an other option from the shell-tool, its not so complicated to form.
https://www.dropbox.com/s/jefzxxfvnul3eww/Gothic%20cross%20Vault%20trapezoid%20ground%20shape.pln?dl=0
Thank you so much! You really helped me out a lot!!!!!
Do you have any suggestions on how to create this angle junction between the dome and the below four arches?
Hmooslechner
This is also a dome but just bigger. Construct it not as triangle - make a whole big dome, and set another on it.
The tutorial-video is in up now.
https://www.youtube.com/watch?v=8djF8KTHBX4
Man...
I love you.
You're saving my days.
We created this object to cover these exceptions:
https://www.archiradar.it/en/3d-objects/objects-on-sale/product/view/50/919
Here the whole library:
https://www.archiradar.it/en/3d-objects/objects-on-sale/category/view/50
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
