Trying to get my head around the new methods for trimming roofs in AC15.
I like the idea of the new "trim to Roof/Shell" command, since it seems to be as easy as the old "trim to Roof" (now "Crop to Single Plane Roof") but acts more like an SEO.
But unsure when you would use the "pivot lines down" setting instead of the "contours down".... any suggestions? Default is for pivot lines, but usually I set my pivots at the wall, so that doesn't work.
Are others using this feature, or is it better to just use an SEO?
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
