urban project - Solid Element Operations = very slow
I am working in an urban project that has a slope land . In order to
create parallel floorsI create slabs that soon short with a duplicated mesh.
The problem is that they "Solid Element Operations" them calculate whenever I open 3d. since I do so that they calculate 1 single time?
Thanks,
Gabriel
4 REPLIES 4
Dwight
Try this - a possibility:
If you save the Element and its Operator as a library part, the calculation won't happen again because it will be scripted directly.
You would put the original elements in new layers and place the library element in their exact place.
Turn off the other layers to hide the original elements.
Might work. Might not save time.
Of course, this might not be the problem at all.
Naturally, Archicad must rebuild the 3D model whenever you edit it, but it is not essential to always rebuild the model when you view it.
See attached for 3D rebuild options.
Dwight Atkinson
Thank you very much Dwight, I am doing what you recommended. He is very laborious but it works. Let us hope that Archicad improves the work with lands.
Greetings,
Gabriel.
Dwight
That particular operation asks for many calculations - they take time.
Dwight Atkinson
I understand, but I need to create a parallel land in height to another one, and need to multiply an object and that in height adapts to the one of the mesh. The form to create this land is the unique one that I can do with the present tools of ArchiCAD
