2011-04-20 10:14 PM
2011-04-21 12:25 AM
2011-04-21 12:45 AM
2011-04-21 02:16 PM
2011-05-02 03:07 PM
NCornia wrote:I did have a marquee actually. I used that to create a section and then press f5 to view in 3d. Should I then delete the marquee? thanks?
Well, I can at least help with the axonometric view question. Go to menu View>3D View Mode>Axonometry or shortcut Ctrl+F3 on Windows.
As to the buggy problem. You don't have a marquee active in plan view do you? I would think not but just checking. If so remove the marquee. Try toggling the F5 key and maybe Ctrl+Y to see if there is some sort of cutaway region causing an issue.
Also look at what other programs are running in the background, including anti-virus. See if anything outside ArchiCAD is interfering.
2011-05-02 03:22 PM
