view story levels in 3D view as a kind of trace?
Hi - does anyone know if it is possible to view the story levels as a kind of trace in 3d view?
I have a series of sloping walls in a matrix triangular design - I need to adjust the sloping walls in 3d view to the story height but I can't see the height of the story in 3d view?
Thanks
You can't see storey heights in 3D.
You could maybe adjust the height of the editing plane.
But why don't you just link the top height of your wall to the storey required.
It can be done in plan or 3D.
You can even set an offset distance if you want and if you now adjust the storey height your walls will adjust automatically.
You could select and view all the walls on 1 story and show only that story in 3D. Then you could adjust the object to the height of that story.
