‎2011-03-24
03:50 PM
‎2023-05-23
02:50 PM
Rubia Torres
‎2011-03-24 03:56 PM
‎2011-03-24 04:02 PM
‎2011-03-24 04:07 PM
kielbasa wrote:Then if you want a sloping change in height you have to use the trim to roof or Solid Element Operations to achieve that.
No, I mean that If you draw a normal wall on a plan, and look at it in the elevation view, you have a square - left side, and right is at same height - and I want them to be at different..
‎2011-03-24 05:17 PM
‎2011-03-24 05:30 PM
‎2011-12-20 12:35 PM
kielbasa wrote:kielbasa, did you find a way to do it? simple wall with rising height without using mesh tool, cut with roof, solid element operations or complex profiles... ANYONE? it seems too simple to be impossible to do! this is the kind of wall that we use every day...
hi,
anyone knows if it's possible to create in AC a wall, so that one side of wall is higher or shorter, than the other side (wall remains vertical).
I could simply build a wall, and trim it to slanted roof, but I have many of them in my project and it's a bit timeconsuming and not very precise.
I also know, that I could easily build such wall with a mesh tool...but I won't
insert a window in it..
thx
‎2011-12-20 01:43 PM
