Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
wall hotspots in 3d don't work
For some reason, in 3d the hotspots on the top of a wall apear, but the cursor can't lock on to them. The hotspots on the bottom of the wall work. And as far as I can tell, hotspots on other types of elements are working too. Any ideas what might cause this? I'm using AC8.1 on win2k.
Djordje
Ace
What tool are you in? If arrow, try redrawing the 3D window (CTRL R) as it MIGHT happen that this is the reason.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I've tried refreshing, I've tried both the arrow tool and the wall tool. Nothing seems to work. All the hotspots appear as they should, and the cursor can latch on to the bottom hotspots, but the top hotspots just don't work, no matter what I do.
I've gone to the extent of reinstalling archicad, and it still doesn't work. I'm assuming there's some sort of setting that gets left over when archicad is reinstalled, maybe a registry key?
