‎2014-09-04
01:45 PM
- last edited on
‎2023-05-24
08:56 AM
by
Rubia Torres
[/img]‎2014-09-04 02:15 PM
‎2014-09-04 04:27 PM
‎2017-05-13 01:42 PM
David wrote:Not sure I understand this. In point one, I select the wall. In point two, I activate the move mode. In point three, I click on something, but if I click on something, then the wall has already moved?
AdriannaTurek:
This is the method I use to move an existing wall a set distance:
1. Select Wall to be moved
2. Invoke Drag command
3. Click on edge or node of selected Wall to be at desired distance
4. Drag Wall to other Wall
5. Hit "x" or "y" key (depending on horizontal or vertical movement)
6. Type distance, then "+" or "-" key depending on direction (in your case it would be "300-")
7. Hit Enter or Return key to finish Drag operation
Others will have a similar but different way to accomplish this operation.
David
‎2017-05-13 02:15 PM
famadorian wrote:The point you select on the Wall in step 3 is the point that will be used for the measured distance in step 6, the Wall has not yet been moved.David wrote:Not sure I understand this. In point one, I select the wall. In point two, I activate the move mode. In point three, I click on something, but if I click on something, then the wall has already moved?
AdriannaTurek:
‎2017-05-15 01:00 AM
famadorian wrote:You click on the wall you are moving, then hover the cursor over the wall from which you want to measure (without clicking). Then type in the "X 3000 + ENTER", again without any clicking of mouse.David wrote:Not sure I understand this. In point one, I select the wall. In point two, I activate the move mode. In point three, I click on something, but if I click on something, then the wall has already moved?
AdriannaTurek:
David
