heathldesign
wall interior line disapears
hello all,
i have a new issue with a 3 wall intersection. everything is fine until i add a third wall, then the interior wall line of one wall. only in this one location so far. if i break the connection of any of the walls, the wall line returns. they are all the same composite with the same reno filter, on the same layer. even if i eyedrop all the settings to, from any of the walls. i've restarted tAC and repaired the file when opening it. i also have no downloaded objects in the file.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
1 Reply 1
Marc H
I was unable to recreate the error. You might try changing your model view to see more detail and trying another composite to have a better sense of what might be causing the issue.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
